TwinTurbo.NET: Nissan 300ZX forum - Fidanza ring gear watch youtube link
njz
on July 20, 2015 at 9:46 AM
Check if Fidanza ring gear is spinning around the flywheel
posted by HillZTT
on July 20, 2015 at 07:48 AM
www.youtube.com/watch?v=Fp4oAsoHyPo
starter doesn't engage when cold
SkiFly01
14:24:46 07/18/15
Turn the crank with a wrench a bit, you may have
njz
21:13:29 07/18/15
No broken teeth, I looked when the starter was off
SkiFly01
02:55:10 07/19/15
check to make sure you have the washer as a shim (n/m)
diamond20601
11:15:36 07/19/15
The only washer I see in the FSM is for the + cable
SkiFly01
01:26:23 07/20/15
HillZTT
07:48:43 07/20/15
^^ That may explain "when cold".. (n/m)
njz
09:39:54 07/20/15
Fidanza ring gear watch youtube link -
njz
09:46:47 07/20/15
I'll have to check into this, best explanation I've seen.
SkiFly01
10:37:53 07/20/15
Yup. Checked your profile to see if you did before posting
HillZTT
12:22:39 07/20/15
One of the video replies was from Fidanza Performance...
SkiFly01
14:37:56 07/20/15
I was able to inspect the flywheel....
SkiFly01
18:22:22 07/21/15
Awesome, mystery solved. Any luck with support from Fidanza?
HillZTT
06:26:11 07/22/15
Called Fidanza, Awesome support btw.
SkiFly01
15:17:46 07/22/15
Good to know. Did they mention any design change?
HillZTT
08:55:27 07/23/15
The Fidanza Tech claimed it to be....
SkiFly01
20:06:26 07/23/15
